MSJKU11
Looking for a viper throttle body for my JKU 11.
Sharkey I didn't know you paint! That's beautiful!
Thanks. I'll try there also if no one here wants to get rid of theirs.
I'm currently running superchips tune. Haven't tried the 91 octane tune yet just started with 87. I was thinking of upgrading the wires and coil also. Is there benefit to doing both body and wires or pointless?my viper needs it lol
I can tell you that the viper body will require you to run a performance tune and higher octane fuel. if you want the same bump without the viper TB, look at swapping out the stock coil and wires for the Performance Distributors kit - you can run a stock tune or the performance tune to get a more responsive engine.
http://performancedistributors.com/product/jeep-07-11-firepower-ignition-kit/
in my research at the time, if you do the TB you're locked into 91 octane since that tune modifies the timing enough to make the TB work. I talked to a few guys and without the tune some would throw a code others wouldn't so I opted to not try it. with coil and wires you can adjust the tune from stock to performance which is nice for me cause there are areas I drive thru that only offer 90 octane as premium.I'm currently running superchips tune. Haven't tried the 91 octane tune yet just started with 87. I was thinking of upgrading the wires and coil also. Is there benefit to doing both body and wires or pointless?
Okay thanks for the info. I did upgrade to CAI and upgraded the exhaust with the tune. I wanted to try TB over wires to upgrade since it seemed easier although neither is rocket science. I may just go with wires/coiI instead. I just replaced my plugs a couple weeks ago and I did end up using the stock replacements. Always mixed reviews of people upgrading both with awesome to no effect. Every jeep is different I suppose.in my research at the time, if you do the TB you're locked into 91 octane since that tune modifies the timing enough to make the TB work. I talked to a few guys and without the tune some would throw a code others wouldn't so I opted to not try it. with coil and wires you can adjust the tune from stock to performance which is nice for me cause there are areas I drive thru that only offer 90 octane as premium.
I think doing both without the ability to hone in the timing would be a moot point and may make it run too lean.
you won't notice much difference from a performance tune with all else stock. imo it's a waste of money to run performance/premium when stock.
no need to buy more expensive plugs either, I've done it and no difference, stock plugs work fine.
definitely don't use the tri-tip E3 plugs, they made mine run like crap
No offense intended, but you should stop chasing unicorns. These modifications are not worth the time or effort. Get proper gearing. There is no magic way to get more power out of that motor.
^This!!!!!!!!No offense intended, but you should stop chasing unicorns. These modifications are not worth the time or effort. Get proper gearing. There is no magic way to get more power out of that motor.
Seems lots of people looking for better and faster ways to ruin their engines just to avoid regearing their axles. Nevermind n that by the time they add all this or that to the thing they probably waisted more money than the regear would have costed.
Sent from my SM-N920V using WAYALIFE mobile app
