Arb leaking air
agiron
I finally got around to hooking up the air hose to the locker. After turning on the air supply I heard air, it is leaking from the diff vent tube. It locks but the compressor run constantly. Any ideas of what my issue is?
Sounds like there is a leak inside your diff. You'll probably have to pull the diff cover. There is a small hose from the air fitting to the locker.
I feel your pain. I'm going through this myself. The shop that is working on mine found the leak from within the locker itself. Leaked within 50 miles of the install. Only way you'll know for sure is to pull the cover. It also could be the copper line has rubbed on something (could be soldered to repair). Could be the seals leaking near the Carrier bearing. Could be where the copper tube meets the bulkhead fitting. You should have the shop that did the work look at it.
