I bet a bunch of people just went to their jeep to look for it.
For those of us without a Rubicon... Yes, it's not that hard to install an inverter. Here, I mounted mine under my DIY privacy cover in the rear. I have since upgraded to a 750Watt (1000 watt peak) inverter.
To find the best one for your needs you need to do a little math to find the size you need, then work form there. You need the right sized wiring and the right fuse beside the battery to match your inverter. The stock cigarette outlet can only handle 10amps at 12v, barring losses, thats less than an amp at 120V.
P=V*I, Watts = Volts X Current. My 750W inverter math goes, 750W/120V= 6.3Amps AC, but will draw 750W/12V= 63Amps DC. At full load, the engine should be running (and maybe revving) Since I ran about 20 Feet of wire, I need to use 4AWG size wire straight to the battery, and a 65Amp breaker to protect the wiring. Thats some heavy wiring for just 6 amps of AC power.
A popular breaker type http://a.co/huP4P8c
Wire sizing/distance chart http://www.engineeringtoolbox.com/amps-wire-gauge-d_730.html
Typical Appliance load chart https://www.georgiapower.com/in-your-community/electric-safety/chart.cshtml
Keep in mind that nothing is 100% efficient and power supplies/inverters are rated for the output power. So if it's 750w but only 80% efficient then it will take more DC power to convert to AC.
750w/120v=6.25A output
(750w/12v)/.8=78.125A
Just need to verify the efficiency of the power supply and adjust accordingly.
Also cheaper power supplies use modified sine waves and some equipment needs a pure sine wave to run properly.
I ran 4 gauge to the back and installed a 1000 watt. It will run a grinder fine and hopefully a small coffee pot this summer.
I'm starting to realize I need and electrical engineering class just to work on my Jeep. Although I will admit I'm learning alot here.
Sent from my LG-LS997 using WAYALIFE mobile app
Yeah mine did not come with one. my inverter looks exactly like yours. I haven't mounted it as I wanted to take it apart and install the outlets next to my emergency lights button. I have 4 spare slots.For those of us without a Rubicon... Yes, it's not that hard to install an inverter. Here, I mounted mine under my DIY privacy cover in the rear. I have since upgraded to a 750Watt (1000 watt peak) inverter.
Sent from my XT1650 using WAYALIFE mobile app
I bought a Rubi for the wall plug. Best $10k I ever spent.
