sipafz
Work continued on my DIY Grill Inserts. The anchors have the best double sided tape I've ever seen! I probably could have just used the tape, but I know in the end it will never hold up to Wisconsin winters so started the tedious task of scrapping it off. After doing a couple with a putty knife, I started looking for a better solution. I need some heat and quickly realized that my heat gun is at work so into the pot of boiling water they go:
Once the adhesive softens, they scrape off pretty easy:
Soak in a little solvent to get the leftover adhesive:
Dry and wipe with alcohol:
I had to make the anchors that go between the openings narrower by an 1/8" to fit, wiped down the grill with alcohol and epoxied all of them:
The glue says that it sets in five minutes and they ain't kidding! I let the glue dry for a few hours and mounted the screens with zip ties:
End result:
I'm pretty happy with how that turned out!
Next up DIY wall mounted door storage.
Really $260 to hang my 4 doors? Don't think so!
End result:
