10abadilla/jk
Finally got my fire extinguisher thanks to my great customer Durbiano Fire!
![20170331_103617.jpg 20170331_103617.jpg](https://www.wayalife.com/data/attachments/210/210588-244fb637f5756a00240e3b8f542a40a3.jpg)
![20170331_103706.jpg 20170331_103706.jpg](https://www.wayalife.com/data/attachments/210/210597-8bad0185df97c070c0d57a955f642981.jpg)
![20170331_103711.jpg 20170331_103711.jpg](https://www.wayalife.com/data/attachments/210/210601-bdae320495016469405b7e75ca6ceb98.jpg)
![20170331_103722.jpg 20170331_103722.jpg](https://www.wayalife.com/data/attachments/210/210606-42c12f5dde762edf6f8ceb26a9f7524f.jpg)
I'm going to weld some skids on. I'll probably pull the zerks out for now and cap them.Switch sides with the arms or those grease zerks are gone.
And I believe the arms are mounted correctly.Switch sides with the arms or those grease zerks are gone.
I was tempted to. I'll probably do it after 500 miles. That way I can grease it when I spin them around.
I think skids will cover them. Plus I will put plugs in them. I can't flip the arms. They have the same bends as stock. If I flip them They will be pretty close to the frame.Don't offroad with them hanging there. They suck to fish out if one breaks.
That's what I mean if I swap sides they are backwards. The bend would then be towards the outside close to the frame. And Johnny joint is to be mounted frame side. So they are mounted properly. I know what you mean but I don't think that is an option for me.
Yea I'm not getting it then. From what I see is if I flip and swap. Johnny joint is now on the axle side. Which is improperly mounted according to core 4x4. And the bend is no longer close to the axle side but now closer to frame side. It looks way off.
Yea I could have. I'll mess with it tomorrow. Sucks I already put the stickers.
