I purchased Xprite headlights, fog lights, and tail lights from Amazon, and have had them installed for about a year and a half.
The first set of headlights I installed did have moisture intrusion issues...they were replaced under warranty.  The second set of headlights had a defective LED within two weeks of install - these were also replaced under warranty.  The third replacement set had a redesigned aluminum backplate with two gore type vents instead of the single vent on the previous version, and an extended rubber tail where the power wire enters the light chassis. I think the new hardware version is likely better with regards to moisture intrusion, but I didnt take any chances - I used clear RTV silicone on the entire mating surface of the light (where the two halves seal) as well as on the wire entry.  The second set of headlights have been on for a year now with no issues.  Low beam performance is excellent with great cutoff.  Combined with the fog lights the illumination performance is excellent.
I haven't had any issues with the fog lights.  My daughter poked at one of the tail lights and dislodged one of the side LEDs that blink wih the turn signal - this was fixed in 10 minutes with a phillips screwdriver and some gorilla glue.
Other than the issues mentioned, no problems.  Installation was simple, the supplied resistors take care of the 'pulsing' from the jeeps electrical system, and the lights have worked well.
Did I get what I paid for?  Probably.  JW Speaker likely packages the light housings better, and therefore suffers less with moisture intrusion.  They may use a better quality LED (Xprite uses Phillips LEDs in the model I purchased).  With respect to performance, I have had my lights side by side with JW Speaker Evolution J headlights and there was no noticeable difference on low beam.  On high beam the Xprite lights have good throw, but there is slight banding from the individual lenses that make up the high beam pattern (illumination was the same, if slightly less uniform).  So for half the cost, I suffered with some aggravation, but in the end I have approximately the same result.
In hindsight would I purchase Xprite again over JW or another high dollar brand?  Sure would.  Xprite customer service was great - replaced every failure with no questions asked and no RMAs (anyone want some slightly used LED lights?:blush
, and the issues that I encountered were aggravating but easy to resolve.  And of course, I have the satisfaction of saving a few bucks and learning something in the process (how to weather seal cheap LED lights? lol).
Right now Amazon prime lists the Evolution J lights for $505, and the Xprite lights are $259.  I think the choice boils down to whether or not you mind having (potentially) to tinker with things. Some people are offended when the things they purchase don't work perfectly out of the box.  I would have been offended if I purchased the JW Speaker lights and they didn't perform flawlessly.  I wasn't surprised when the Xprite lights weren't perfect, but it didn't bother me that much because I like to work in my garage - hell, thats why I bought a Jeep!
