jeeeep
I'm wondering how many of you running 37's have had to replace the bearings on rear axle shafts after 1 year.
I had G2's installed March 2016 and I'm already getting a rolling squeak.
I did a visual check on the flanges and they appeared to rotate fine (I need to put a dial indicator on them) and no bent flange squeal like before when I hand rotated then tires.
As I rotated the wheels I could feel them grinding, also felt them grinding with the wheel off - both sides.
I find it hard to believe that they would already be failing unless it was installer error, does anyone know if G2 axle shafts are pre-assembled? I'm wondering if they were greased properly.
I plan to reach out to G2 in the morning, it'll be a full year on March 26
