Where did you route your breather tube through? Was it still able to use the stock ford spot?Artec swap
Ruff stuff cover
5.38
Grizzly locker
I can only post screenshots of the pictures I took which is annoying
Sent from my SM-G935P using WAYALIFE mobile app
I installed mine right on the top. Artec had already given me a hole.Mine has a nothing bolt there. Im gonna bore it out, tap it and call it a day. For my air locker cable im gonna use the ford abs hole and take the copper tube through there.View attachment 248062 I installed mine right on the top. Artec had already given me a hole.
welding on the rear has started, but we ran out of gas. Still need to order the artec tone rings. Brake calipers are all sanded down and primered ready for paint.
5.13 gears, arb lockers, rebuild kits and arb compressor. Ready to go in once the rear is weldedMy question for the 60 swap, does it have to be within a certain year vehicle to be able and swap it over in a jk? I'm trying to learn this stuff and I have no clue really so maybe this can one day be an option for me
True factsFor junkyard axles, it just means different mounting and ABS options.
99+ or 2005+ are different. Both can be used.
Check out "coming up to speed with grubbicon." He did a super duty swap on his JK and used the different master cylinder.Ok seen mention of needing different master cylinder to run the ford calipers, but no mention of which one. Getting ready to help a buddy out and do his swap, what did everyone use? Thanks in advance
had to buy new brakes, i tried to save the stock ones but rotors and calipers had way tomuch damage to them.
