Isn't there a new "Tow Rig" forum section? This belongs over there![]()
Its just the tow rig show thread...
http://wayalife.com/showthread.php?43510-Welcome-to-the-Tow-Rig-Forum!
Thanks... I should have scrolled down further. sorry..
A. Outlet of points to ponder.
1: Get a bigger trailer than you think you need. 20' minimum.
2: Get 5,000 lb axles. Better brakes. Higher weight capacity.
3: Get brakes on both axles. Safety first.
4: Consider a deck over. Wider axles & tires might require it.
I agree with the above.
Get a big trailer. Get strong axles.
I like D-rings to the axles but do Y straps over the tires. I think D-rings are better because when you stop the rig doesn't 'roll' forward (an inch or two). Plus with the D-rings to the axles you still have the vehicles suspension to absorb some of the bumps.
Thanks, I was looking into a 14ft trailer but changed my mind. The most I can do is 16ft due to the limited space on my driveway. D-rings are on my want list too. I was thinking of strapping the axles and additional straps to the bumper. You think that's over kill?
Someone else on this thread said Mac's Straps.... I'm planning on that too...
Any opinions on the below link for Sure Trac?
https://www.sure-trac.com/products.php?trailerId=14
[. Lasso straps (Y-straps) suck ass. All manufacturers will not allow us to use them for a reason, they don't hold very well and also can damage the wheel.
There are lots of ways to secure a vehicle but I would never recommend using the d rings on a bumper as the primary restraint. All it's takes is one good bump and the suspension can cycle enough to create slack in the strap causing the load to either shift or become dislodged. That is why I recommend the axle strap method. Now if you want to back up your axle straps with another set going to your Jeep d rings that's plenty good. Overkill? Maybe but if it keeps you from being distracted going down the road then go for it.
16ft should be fine for a 2 door, that's what I used on my tj. I have always hooked to the d-rings and kept straps at 45 degree angle to pull the jeep down to the trailer and have never had an issue. But with my new jeep I used macs axel straps too and I'm glad I did, because my new jeep has a lot more suspension travel and one of the straps hooked at the d-rings came loose coming back from Texas. View attachment 248406
