So i have searched a bunch of steering issue posts on here, but i would like to see what you guys think about a clunk and not just flighty or off steering.......I had the lift in since Jan 7th and the clunk started about a month after, and only after i turned the drag link collar one more turn to straighten my wheel.....coincidence????.....also the clunk happens over bumps, but not all bumps, but happens every time i crank the wheel to the left, like to make a circle, and then back to straight, but does not happen to the right.......almost sounds like i am dislocating a bone and then popping it back in......best audio i can give you lol
'08 101K new Rough Country 3.5" lift with balding 315/70R17's....everything else is stock
So far this is what i have had done, from a 4X4 place near me, or done myself in the last month.........
All 4 ball joints replaced along with passenger side u-joint (they said driver side seemed fine)....shouldve just had them do it....but i digress
Replaced drag link (as it seemed to warp a little they said) with Rubicon Express and flipped it to the top....still using the drop pitman that came with the lift, and the track bar bracket on axle side.....bars seem pretty parallel and can send picture after work
Welded homemade washers from 1/8" steel for the track bar on the frame side as the bolt wiggled around a bit in the original holes
They took off a tie rod from his JK and put it on mine just to rule out the ends, and the clunk was still there, so they put my stock one back on....good guys just trying to help
So our last thought was the steering box.......i mean what else do we have left????
please help because i would rather not spend another $250 on a new box to still have the clunk......if that happens i'm driving it till something breaks...bc then i'll know what the problem was....:cheesy:
Thanks in advance
Thanks in advance
