Jmjnewbold
Can you charge the ipad mini while it's in the mount? Doesn't look to be possible from the videos and images I can see. Also, are we certain that the ipad mini 4 won't work in this mount?
You can take the iPad out fairly easy but I usually just pull the whole mount off as it is easier. And the iPad mini 4 is a no go. It's close but a little too wide and def too long to fit
Yeah I totally looks like it would be easy to pull out. Just wondering if I could charge it while in the mount.
Hahah sorry I misread that. Yeah you can easily charge it in the dock. It has a flap that opens to give you access. But there is plenty of room under there to hide a charger if needed
Well I'm not an electrical engineer but there are a couple of hurdles to overcome. The keeps gps antenna provides signal to the headunit through a coaxial cable. There's no input for this type of connection directly to the iPad. At best you could plug the antenna into a dongle that could transmit the signal via Bluetooth or wifi which seems a lot more trouble and expensive then just purchasing a $20-30 gps dongle. Unless there's is an adapter that goes from lightning to coax and there is an app to support the connection I don't see how it could be pheasable.
There are several different brands in that price range. Those two are just ones that I am familiar with that have a good reputation.
Here's one for instance.
I checked the measurements of the ipad mini 3 its 7.87 x 5.3 x 0.29
The Galaxy Tab S2 7.82" x 5.31" x 0.22"
Sure seems it should fit...
If not they will be coming out with a tab version they said just no eta
Looks good...not sure about the Beyoncé playlist though [emoji23]
I was asking about this as well being that Moby is a 2007 and I can tell you that a version for them is in the works. Hope to see it out soon [emoji1303]
Watch WAYALIFE YouTube Videos
WAYALIFE Jeeps & Specs
Very nice. I only have radio no screen system, can i use it?
