metalic
I don't ever get over that direction. I don't know if you ever get that way but i will be at SMORR at least once this year and should be at Flat NASTY for the bouncer hill climb.
Sent from my SM-G930V using WAYALIFE mobile app
Yes, it is a Rock Hard harness bar. I pulled the driver side rear seat out a while back and carry a fridge there but on the passenger side, I do have a pad on the bar for just in case. It's otherwise not a problem for them and it's something to hold on to like a chicken bar.
Do you know if you would still be able to fold down a stock rear seat with the harness bar?
I like that feature
I tend to slide out and my stock seat is showing foam on that lipAnother question . Has anyone had wear or tear issues from the outside lip portion where you sit. I can tell the foam on my stock seat has noticeable worn since new.
Sent from my Nexus 6P using WAYALIFE mobile app
I like that feature
Your stock rear seats will be able to fold forward still, no issue with the Rockhard harness bar installed.
This happens a lot. I never had it in a JK, but did in other vehicles. I put these seat covers in my 2 door, just to change the color.
They are from leatherseats.com & are the vinyl option. They fit great. They do take some time to put on.
Those look like a factory fit and look great :thumb:
Like everyone else here, I personally would recommend the Mastercraft Baja RS seats. Been running a set in our 2007 JK for over 6 years and have been quite happy with them.
Here's a couple of shots with a Rock Hard harness bar installed.
