WAYALIFE on the GO : Miscellaneous Photos from Cindy & Eddie!
Since we had everything apart, we decided to clean up and repaint the EVO Lever frame.
Got the new cantilever arms installed.
And, since we're still waiting on parts from King, I decided to use the time to service the differential.
That's a beautiful rear end you have. [emoji41] I can't wait till I get a setup like that.
Out in the Boonies
Some stupid questions: the bend in the track bar, does it need to be there so when you up travel, it's there as a cut out for the driveline?
How do you adjust ride height?
The track bar is backwards compared to stock. It's this way b/c of the Evo lever. I'm sure you adjust height based on much preload you put on the coilover.
It looked like the horizontal part of the lever was welded to the sway bar for the longest time until I finally saw in the last pic it was brackets welded to it
