Slimebones
Broke my driver side ft axle last weekend. Ordered and installed right side Revolution chromoly shaft. Having trouble getting driver side in. Will not slide right in, hitting bottom of knuckle. Acts as if knuckle is bent. Note: I did notice the bottom ball joint had come loose and had considerable slop as if hole might even be wallowed out. Tightened ball joint nut. Axle still does not slide in, hitting bottom in knuckle opening. Can the knuckle be bent? I do have c-gussets welded in, would not think c would be bent. Anyone have this happen? Need suggestions. Thanks.
