Dynomax JK Wrangler QuietCrawler Exhaust Installed on RUBICAT w/EVO Lever System
I was thinking more like the four-door system, just with the race bullet moved behind the axle.
The muffler would install in the same location as the four-door, then a pipe running from the muffler over the axle to the bullet mounted left-to-right where the stock muffler is. Then just a 90° with a tip. The only difference from the four-door kit would be the intermediate pipe between the muffler and the bullet, and then the outlet pipe.
That should sound similar to the four-door kit, but give a lot more clearance than most of the cat back systems out there, and still have a rear exit rather than a dump before the axle.
So a two door gets really tough packaging wise. If I understand correctly, putting the Bullet first is similar to our "Evolution Competition" system.
PN 39522 for the 2012-
http://www.dynomax.com/single-2-5-cat-back-system-ultra-flo-polished-muffler-39351.html
PN 39516 for the 2007-2011
http://www.dynomax.com/catalogsearch/result/?q=39516
Also a Race Bullet is loud like think only a few dB's below open headers.
Maybe something like this?
http://www.thrushexhaust.com/new-products/thrush-rattler-muffler-center-center-24254.html
18" overall
http://www.dynomax.com/super-turbo-offset-offset-17886.html
18" overall
So just those 2 mufflers (no tubing) is 3 feet.
Gotcha!!! Throw the Bullet in the back (where that bulky stock is) and keep it up high and tight!!!!
Is there an update to this system? I find it out of stock most places. Sure sounds great. I got the Magnaflow Off-Road Pro but with the new 3.6L it just sounds like a ricer. Wish I found this thread before then.
The last time I talked to him, there is a still one part of the kit on backorder due to the high demand. Still, if you send Dynomax a PM, they can supply you with the part #s for the rest of the parts. You could always buy the parts, and then have an exhaust shop build the other piece for you. It is a great sounding system for sure.
What's the issue? See my install thread in the How To. I also have the Evap skid.
I checked your install thread and you do not have the EVO MFG Evap Skip plate, only an Evap Skid plate, which is stock. From what I can tell, my EVO MFG Evap skip plate is huge and covers the stock Evap skid plate, so there is not a lot of room between the frame rail and the plate.
Here is an updated pic.
I'm going to start on this, soon. Eddie, I'm borrowing your idea of welding an exhaust hanger on a U clamp. That's a great idea, if my welding skills can pull it off!
