View attachment 239742Not clear if you are planning to correct the gear install (you mentioned possible issue on the install?) or just address the leaking seal issue. Agree with the other posts, the seal could be leaking due to a bent tube, but can you provide more background? Major or minor leak, and did it start after a wheeling trip or just started? I have seem guys gouging seals during install of the seals or when inserting the shafts back in.
Plan for about 3-4 hours. I will skip to removing the carrier, there are plenty of videos out there, below are just a few tips that hopefully will help out.
Removing the little connector for the front locker is a bit tricky, remove the top small bolt (I am thinking 7mm or around that) pull gently up and use a pin or pointy tool to help slide the two connector parts, then pull down gently from the inside. Take pics of the carrier and bolts prior to removing and make sure to use the same bolts in the same position as removed. also make sure to remove the carrier gently as the shims for the bearings will drop out and need to be put back on the correct side.
To remove the old seal, I used a rod and large washer and tapped from the outside. With some love it will come out (that is what she said
) One trick to replace the seals (since you are there might as well replace both at the same time) is to use a long piece of pvc pipe, then I believe I used a 36mm socket which fit perfectly on the seal gap without impacting the seal. I recommend installing the short side seal first.
Pic of my broken shaft (also caused seal to leak). Mallcrawlling for life!
Good luck, take your time and have fun
