Stock tie rod stabilizer bracket hitting ProRock cover
Fox also make a pretty nice tie rod SS clamp, IMO it's more streamlined than the synergy clamp. My buddy has the fox on his and it looks good.
http://www.ridefox.com/accessories.php?m=truck&ref=topnav
if you plan to run hydro assist you'll want to look at the PSC clamp, synergy and fox are not rated for hydro assist.
http://www.pscmotorsports.com/motorsport-specific-products/offroad/tie-rod-components/tie-rod-clamps
btw I couldn't find any pics of mine flipped to point down, I'm running hydro assist now using the PSC clamp
Thanks for the info on the tie rod clamps, guys. Looks like that's the best way to do this. I just ordered one from RockHard4x4. Looks like it should fix it. I'll post back after I get it on there.
Should have added that if you are using the stock tie rod you need the 1.375 {1 3/8 } sized bracket not the 1 5/8 one
Thanks for adding that. I measured with a caliper last night. I noticed there were a couple different sizes available. :thumb:
Update: The Rock Hard 4x4 tie rod clamp fixed the issue. :thumb: Thank you all for the clamp recommendations. And the 1/2 inch supplied bolt fit in the Bilstein sleeve with no drilling. The new setup clears the cover and the drag link.
Full left turn:
