WJCO
Meme King
I'm hoping a member or two that is running a ProRock still runs the stock tie rod. I've got an issue that I thought was worked out but not completely. I have my stabilizer above the tie rod like lots of guys do, but noticed the bolt head on the bracket ever so slightly hits my new ProRock cover. It actually wore away enough of the cover that it stopped binding so I'm OK with that. However I noticed a new problem today, up higher, the bracket bolt is also hitting the drag link over bumps. The easy solution would be to just rotate the bracket so the stabilizer would be closer to the axle and would easily clear the drag link, but if I do that, the stabilizer bracket will definitely hit the cover more and likely I won't even be able to turn left at all. So for those of you running a similar setup, any ideas?
Here's the witness mark on the drag link showing where the bolt hits it:
And here's showing the bolt where it hits the cover. The bolt head slides right over the Dynatrac logo and it wore enough where it doesn't bother me. But if I rotate that bracket, it will hit much worse:
So in summary, I'm trying to rotate the stabilizer in more, but I can't do that without hitting my diff cover.
