Commando Green Rubicon
Did my 1st oil change and went ahead installed a K&N air filter.
Wasn't sure how I was going to like the cartridge style oil filter vs the spin on style because of my wife's Chevy Cruze would always leak at the cap. Seems to be better than GM.
Lift is done. I'll take better photos in the am.
6 hours, Rockstars and 4" Enforcer.
Big thanks to Charlie(Jackal), couldn't imagine doing it alone.
Rockstars Skids
Went with the JKS Draglink Flip. Have to say I prefer it over the Synergy kit I had on my last Jeep.
Extended brake lines installed.
Took some quick photos in the driveway.
On order rear shocks and front driveshaft.
Got a few more things done this week. Got the stock rubber coil isolators in. Luckily I was able to find some from someone going to coilovers.
Made some rear links.
Rear shocks and rear sway bar links installed.
EVO rear d-ring mounts.
Replaced my gas cap, no reason other than it looked cool and I had a giftcard.
Those links look great! You should spray your frame with tire foam and it will look just like the plates on your d-ring mounts. It cleans the underside nice
