Why did my battery run down so quickly?
Did your build sheet list the flux capacity of the inverter outlet by chance? If not, you'll have to manually divide the amps by the watts minus the voltage plus the relative humidity divided by the ambient temperature. Then take that number and add it to the percentage of Copper content in both the wiring at the battery and the wiring at inverter. The difference will get you the flux capacity. Report back.
