I guess as long as it's not that bad, then it's not a huge deal- unless it's drives one crazy..
you'd think that'd be the case but I've always heard coilovers make some noise, sucks your rear ones are so loud
why is that? I honestly don't know a whole lot about coil overs/dual/triple spring set ups
Sent from my SM-G928V using
WAYALIFE mobile app
I think with the Kings having threads on the entire shock body, it makes it nosier then most. I have been told that it looked like the slider was binding on the shock body from the guy behind me while going over some messed up terrain at a slow rate of speed. IMO this is what causes the clanging twaingie sound. almost like one spring went so far, then the other one kicked in. I tried to run out and get a video but that damn thing wouldn't make any noise. Figures
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
If you look at the Sway-Aways I posted a pic of, the lower half of the shock body where the slider cycles is smooth, it still made noise.
Well I haven't done any wheeling yet...maybe that will make it all better lol!
AGM sliders and turn up the stereo haha!
Too bad it sounds like this...
Sent from my SM-G935V using
WAYALIFE mobile app
Id put coilovers on this and smash this bitch out too :thumb:
Ive done a bit of wheeling on this suspension and it still makes noise, rocks, dirt, in the mud, snow etc. I guess it just doesn't bother me because I've had coil overs on everything.
It is my understanding that the way the spring on a coilover work, you have an upper and lower spring on each shock body, isolated from each other by a slider. As the shock cycles through and the springs compress and rebound, the slider moves on the shock body to compensate for the change in spring length as the suspension cycles. The noise I believe comes from the slider moving against the small rings around the shock body, if the shock body were smooth, i would think the noise would be much less but from what I understand those rings are used to set preload. Sorry if none of this makes any sense as I am still learning about this stuff too lol.
Sent from my XT1031 using
WAYALIFE mobile app
Your on the right track. The top rings set pre load and ride height. The inner rings AKA gas stops, spring stops, stop a coil and activate the second coil. So when the upper coil is stopped, the lower kicks in.
