Here is what I'm looking at:I was just looking that up too. The manual says that's a standard mounting bolt pattern though, so the Maximus 3 mounting bracket itself should probably fit the PowerPlant on it, as long as you trim the bumper to fit around it.
As nice as the MOPAR 10A / X / HR bumper looks, it's not going to be as strong as the LOD or EVO bumpers. They are really heavy duty welded steel, with the stinger welded in. The steel in the MOPAR bumper is thinner. The Maximus 3 stinger looks at least as durable as the MOPAR bumper it's made for, but still not quite as sturdy as a bumper that has the stinger welded on.
If you're thinking about getting air lockers down the road though, I say start building for the way you want your Jeep to be when it's all built and just get an onboard air setup from the start. All told, the price of an ARB compressor and a Zeon winch is comparable to the PowerPlant, and it will save you and extra purchase and some duplication of work later on.
I hear ya, upgrading all that can be pricey. By "not as strong," I didn't mean to imply that the MOPAR 10A / X extras won't be good enough to get the job done. Even if you went with the EVO front bumper, I don't think there is any real need to change the rest unless you really don't like the look. If you do, at least you can try to sell your take off parts to make up some of the cost.
I'm more of a mind to keep the 10A / X extras on there and getting things to add on to them. I paid the extra for the special edition package, and I did it both because wanted something more functional start and because I do like that look.
If you're looking for tire carriers that work with the 10A / X bumper, you can either go with the AEV carrier (mounts to the frame through a hole in the bumper), or any of the other designs out there that don't attach to the bumper at all.
While I agree there are stronger/better bumpers, your assertion that the 10A bumper isn't that strong or sturdy I disagree with - its plenty sturdy and strong. Could you have a heavier and stronger bumper? of course, but I just want to put it out there that it's going to hold up to 95% of anything that anyone here is going to throw at it.
... By "not as strong," I didn't mean to imply that the MOPAR 10A / X extras won't be good enough to get the job done. ...
 cheers!
cheers!I'm about to do this exact install, and I can't thank you enough for your write-up with pics! It will make the install a lot easier.
Nice write up i have the same bumper and went with Maximus winch plate and the license plate bracket.There was no need to relocate the pump since i am ruing smittybilt x2o winch
my license plate bracket however is different and is located below the fairlead. So far did not have any issues with clearance on the trail.
Great thread OP! I installed mine today but I'll tell you I'm having a rough time getting the bottom inside nut on the driver side stud. Any advice on this would be great. Maybe i need to do more trimming on the factory vac pump mount and try it again. Hope to finish it up tomorrow. Thanks for any advice.
Getting real close to pulling the trigger on this same plate, but not sure yet on winch brand and weight stamp. Thanks for the write up OP, I will be revisiting this very soon on my installcheers!
I just helped my Buddy put his Zeon 10s in last week. Thank you, Thank you, Thank you OP for the pics you posted. After trying to figure things out with the Maximus directions, I got my laptop out and opened up this thread. It helped a lot! We wound up moving the 4 backing plates on the frame to the front as spacers, and we drilled two 3/4" holes in the bottom of the bumper to access the front winch hold down bolts. Worked great. My Hard Rock should be here in a couple of weeks and it should be a piece of cake now that I am a "practiced professional" Maximus-Zeon installer. (now where did I put those hole saws?)
You're welcome! I'm still rocking this setup and it still is great.
I've banged mine quite a bit as its removable and I never remember to remove it.
I had trouble with a few as well, just hang in there and you'll get it. A few tools were thrown during my install.
Thanks!
 . Thanks again OP!
. Thanks again OP!
Installed mine last Saturday! Took awhile, but well worth it. Thanks again OP!View attachment 241773
