BertaNation
I am installing the synergy drag link and adapter with no success. Drilled out my oem knuckle w to 7/8 with a step bit. Installed the synergy tre adapter. Had to give it a light tappy tap to get it in. Installing the tre did not go so well. Would not push into the adapter easily so I put an oversized socket over the top to give it a little persuasion. Got it down far enough to catch a couple threads w the castle nut. Thought I could bring the tre down w the castle nut. It's not working out. I got several turns out of it but it is definitely to tight and I am afraid that if I keep going something is going to get damaged. Any thoughts???
2015 jku
2015 jku
