JKS adjustable spring perchs
Crso8541
Does anyone know if the JKS adjustable spring perches are compatible with Rock Krawler rear trackbar bracket? I've adjusted just about everything to keep my trackbar from rubbing my passenger coil and this is my final thing.
I have the email for the tech guy at JKS if you want to ask him. He answers email promptly
Did you axel stay centered
Yep. My axle has a welded on raised bracket as well.
Did you do the X-factor where it moves the axle back an inch? I did and that was my biggest issue. My coils look like slinkys even with the correction wedges installed. Track bar whacked the shit outta the raised bump stops and track bar hit the diff cover too. Putting the stock track bar on helped with clearances and I had to trim the rear pinch seam by about an inch. Honestly I gotta say it cycles pretty damn well now.
