I have cj w/ outboarded RE1444 and RE1445 specifically designed for SOA, and am running scout D44's. It flexes pretty well, as yj springs do over cj's anyway because they are flatter, having less arch. I like my set up, but it is really about what your going to use it for.
There are other considerations needed for running a SOA, such as axle wrap.
Sent from my SCH-I405 using WAYALIFE mobile app
What are you running for fender flares?
If still the stock YJ, I would suggest looking at changing to TJ flares. The TJ cut out helps alot. You basically take the lip off starting at the top of the fender opening and then as you work down to the back, you cut more and more. About 4-5" off the inside of the fender.
Makes for alot more room out back.
Here are a couple of installs
http://bc4x4.com/tech/2001/tjflares/
http://bc4x4.com/pv/yj/tjflares/
