matt87951
As the title states, I am looking for some feedback on the shocks to go along with the EVO Enforcer kit, specifically the 3" kit. I have a 2013 JKUR 10th Anniversary, and it's been at stock height long enough. Last time I was out I got stuck in a stupid spot, so some additional height is needed. I have pretty much concluded that Rancho 5000x shocks would work great, but since these are kind of new, I haven't seen a ton of info out there, though the reviews I have seen are positive. I am also open to other options, but at the same time trying to keep the cost relatively reasonable, considering the Enforcer kit isn't the cheapest kit, though it does appear to be one of the most complete.
I believe the part numbers I would need are: RS55329 & RS55330, correct? I have seen reference to the 331 & 332 numbers also for a 3" lift as well, so I want to make sure I get the right parts.
Outside of the lift, shocks, and exhaust spacers, is there anything else I need to run this lift? I do have factory wheels (and tires) currently, so I do also understand that I would need to either replace my wheels or get wheel spacers when I go to 35's. Is there anything that I am forgetting, or something that others have found is really something that should be done? I have seen yes and no on a driveshaft, seems 3" should be okay, but anything beyond that definitely needs one.
Here is a photo of me stuck, hopefully the lift and larger tires will keep me from getting stuck in something easy like this. Hard to tell from the photo, but I had no traction front or rear at this point, and had to be yanked over the hill by my group.
I don't really plan to run anything larger than 35" tires (currently), however I definitely want to keep stock fenders for now. Eventually, I might move to 37's, but that opens a whole new discussion, so I want to keep my jeep build rather low key currently, and if and when I want to go bigger, I already have what I believe is a pretty good starting point.
Lastly, any recommendations for a one-stop shop to order all of the components, at the best prices?
Appreciate it!
-Matt
Appreciate it!
-Matt
