MR.Ty
Token East Coast Guy
this was my question:
As I mentioned before i am searching for something similar to what we see in bicycles front wheel (clamping the wheel) but on larger/heavier side: https://www.google.com/search?q=bicy...J_jVo_BhlWM:
But with a swivel pin on the bottom so i can pull it up once unclamped.
where was it answered??
They didnt give you the answer you wanted because there are no "clamping pins" that will fit and put pressure through the whole latch and bracket to eliminate the squeaking you hear.
Eddie told you how to fix it, then Pig gave you a different solution and then Ddays gave you another pin set up to try.
