ttfhell
I'm sure there are a lot of reasons, but a few that come to mind are: ability to run 2 springs with completely different spring rates on a coil over. Able to get a lot of travel with out worry of unseating a spring. Mel works closely with king to get the valving and spring rates just right for a jk. Other companies may just be using a generic coil over setup using theoretical numbers. Although coil overs are not the only rebuild able shock, once you purchase other high end shocks that are with springs ect, you come close to the cost of coil overs anyways. I haven't seen many instances where a spring/shock combo produced more flex than coilovers (metal cloak lift may be close). Coil over shock bodies are pretty massive, looks to me that they hold a lot more fluid volume, which is good for high speed stuff. I just rode in and fallowed my a rig on coil overs during tds. I in no way could keep up and while riding along, the faster we went the smoother it was! That was just on the evo bolt on's, double throw down and evo lever must be insane. The ability to do 70mph down a wash that my rig was getting beat up on going 20mph is just awesome. I haven't seen any that went to coil overs switch back to coil and shock. These are just my observations and may not be fact, so flame away!
As the guy The Duff was riding with above I can tell you that they are awesome. I had a Teraflex 4" kit before which is a solid kit but if you go over any wash board type roads at 15plus you feel it let alone any whoops. I just have the bolt on kit and front air bumps and it is night and day better. My motto on the weekend was if its feels too stiff, go faster. Worked every time. Better than this is even at the lowest hight it's at 3" or so there is enough articulation to help on these rocks the same day you haul ass down the road.
Best purchase yet.
