Kyle7R
Do those equal out to about a 33"? Considering this size.
Right around, a skinny 33" if I remember. You might also look at 295's as well.
[url=https://www.tacomaworld.com/tirecalc?tires=285-75r17-295-75r17]
[url=https://www.tacomaworld.com/tirecalc?tires=285-75r17-295-75r17][/URL]
Aspect ratio is 70, not 75. I'm prob gonna go with 295/70R17.
They're claimed 32.7". I've looked as well. With weight of Jeep on them, they're right about 32". See this thread: http://wayalife.com/showthread.php?35075-The-Ultimate-TRUE-TIRE-SIZE-Database.
I was running 285 70 17s on my 2013 2 door and I would run the fender flares when disconnected. I installed TF leveling kit and extended the front bumpstop I think like 1" and I had no more rubbing. You can also solve the rubbing by trimming your fenders up a little. I used JKS quicker disconnects and they worked fine for me.
On a side note, what wheels are those? I'm digging the look of those!
As ausjeep said i'm not sure if Suspension stuff are still selling them as i've heard the same but they are still on their website, but here's a link for Murchinson.
http://www.murchisonproducts.com.au/shop/crdstu-jk-front-coils
He is definitely still selling them under his CRDSTU line of suspension parts. they are probably made by King under licence as they are about the only coil spring manufacturer in Aus.
As for shocks the 7000s are a monotube like the bilsteins and fox 2.0 where as the 9000XLs are an older style twin tube adjustable shock. I went with the rancho 9000s because i had good experience with them in my WJ and i was able to get the delivered for under AU$500.
Yeah Stu still has them but I tried to get a set through suspension stuff and they have just been bought out by another company and decided to discontinue them. They said Stu is the only guy that would have any left. From everything I've heard though they are a really good spring and great value for the money, I was looking at a set for mine and still might get some. If you wanna get good cheap shocks go with 2nd gunman and get the 9000's I had them on my old Xj and they are really good bang for your buck shocks.
Hi, I have a question,
ur jk, which in the photo, only add 1'' TF leveling kit? I feel it is higher.
The TF leveling kit adds a 2" spacer to the front and a 1" spacer in the rear. Here is a picture of the same kit on my current 4 door, getting ready for a fender trim and 35s.
Before
After
As you can see, it does make a big difference and plenty for around a 33" tire or even a 35 with trimmed fender flares.
Before
After
After
Does the TF leveling kit come with bumpstop or break line extensions?
what parts include in these kits?
Not trying to hi-jack the thread, but what bumper is that? I don't recognize the symbol cut-out.
Ok thank you. I will do some study on rancho. and does rancho have sales in australia or we need order online?
thank you for your info so much
I'm pretty sure they're the new mopar beadlock so that came out a few months back. ~$275 from what I've seen.
I guessing your joking. Those are steel wheels the mopar bead locks aren't even available in Aus
yes, I custom made these steel wheel.
