TonyT
What about a portable compressor? 37s.
I've been running 37's since I lifted my JK back in 2009.
I started with the single ARB mounted under the hood. 12 up to 38 psi took 6 minutes each tire and it would shut off due to heat on the third tire most of the time. After about 10 minutes I could finish up.
I then went to a VIAR 440P, better at about 4 minutes a tire and could do all 4 without shutting down, but afterward it was difficult finding a spot to let it cool down. I ruined a tent, and a few other things that shifted while driving and leaned up against it.
Then I went to C02. It's incredibly fast. 7psi to 38psi in about 1:40. The only drawback is planning ahead and getting the tank filled prior to wheeling. I just bought the Powertank Kit, then a 20# cylinder from the local welding supply store. That way I just go in and swap it over for a filled one. ($18 each time) I don't run air tools off of it, I tried a reciprocating saw once when I cut my factory flares and was surprised how fast it drained a full tank.
A friend of mine has the ARB Twin Compressor and its awesome. I think I will pick one up as a backup when I neglect to fill my C02 tank. The only problem is after he fills his (he's on 35's,) and I'm airing up my 37's, the compressor gets hot, the lines soften and blow-out. I'm not sure if thats common, or just an issue with the way he has everything plumbed.
Good luck. A friend of mine always says "It's twice as expensive if you have to do it twice." So really consider what you need and go above that. Also, don't forget to take into account the hoses and inflator you use. The VIAIR inflator that came with the 440P was junk. It inhibited air flow. I used an ARB inflator and it was significantly better.
