Codes P06DD & P0513
srosario
ok so for a million reasons havent check my oil in 3 weeks,
two codes came up last night, check the oil and it was down 2.5 quart. no low oil light. i have cleared the codes and they still on.
any help
any help
There is no such thing as a low oil light. A light will come on when you have 0 oil pressure. It's usually to late by the time this happens, damage has been done.
Codes P06DD & P0513
ok, do u have any idea what those codes are.
online : DUAL STAGE OIL PUMP STUCK LOW
INVALID SKIM KEY
INVALID SKIM KEY
I'm not sure. Probably oil pressure problems related to low oil level. By now you must have topped off your oil level. Could be oil pump issues.
I just had these codes on my 2015 jk with only 28000 miles on it.
The dealership tried replacing the oil, oil filter and oil pressure sensor but the code came back. Finally they replaced the oil pump and I haven't seen the code since.
Codes P06DD & P0513
damn that sucks. im out of warranty,
im thinking the pump messed up seens it was low on oil
edit: update
no more lights, i use the vechicle about 6 times after i topped it off, i guess it reset.
Codes P06DD & P0513
I've heard a few guy on here say to use Dino oil instead of synthetic and that helps. Not sure if that was on a 3.8 or 3.6.
Mainly because nobody likes to spend the extra cost for synthetic while it's disappearing as fast as you pour it in.
Codes P06DD & P0513
Ah ok just could not remember. Figured someone would chime in, mine at 25k just started using oil 2 quarts every oil change.
Thicker oil can help alleviate clearance problems, however with a more viscous oil than recommended, it can delay the oil getting to the top of the engine on startup causing premature valve train wear.
