I bought the EVO winch / light attachment for the 1/4 bumper. I then bought 2 cubes from Inspired Engineering. They are a plug n play with the OEM wiring harness. Very simple. Plugs right in. Controlled by the OEM fog light switch. Easy project.
what did you guys do with your wires from factory fog lights, and also where do you mount the relocation bracket from EVO at?
So just tucking it back there won't do any damage to the wires?
And where exactly does the EVO relocation go? Sorry I'm just having a tough time with the instructions
I loosened both sides of the sway bar and removed to bolts from the passenger side. I installed the two plates on the passenger side first. I then installed everything into the bracket. Then on the driver side I installed the bracket and the plate. The bracket was the lower part then the plate. It looks harder than it is.
Hope that helps a little.
I'm going to need to drill holes in the top of the bumper for the stinger correct?
So does EVO send 2 bags of bolts for the bumper? Because I have 2 packages of the same hardware
