Hammmerhead
I have these on my LCA's and was wondering if anyone has any tricks or which wrench worked the best to break them loose?
Pipe wrench
Quick question, is the threaded sleeve with the big adjustable nut on it regular thread or reverse?I use channel locks, but mine are not "spanner wrench" they are actual hex...
I installed mine with the adjustable collar all the way in for some reason and they need shortend little bit. Ill have to pull them regardless looks like.I used a 15 inch Cresent with an extension and it worked fine both on and off. Should be standard threads, at least I do not remember them being reversed on either side. Hell try to tighten it and clear up the guessing. It will either not move or come loose![]()
Thats pretty much what i did the first install, i just didnt realize how the inner sleeve worked till they were already installed. It handles great but im at like 6-6.5* im sure regearing will cause some driveline vibes if i dont get back closer to 4.2*. Once i fix it though, i want to be able to utilize the on-jeep adjustability if they are designed to do that.Try to get a basic measurement to set them up at, install and do your alignment and make minor adjustments. I can give you the center to center start but my coils are set up for a 4.5 lift. If anyone has a similar lift to yours you would be good to go with that measurement as a start. The first time I set up some EVO lca's I was all out of wack. Center to center and equal adjustments on both ends made the alignment way easier.
You talking about these nuts?
So is the intent to make the initial adjustment length to the arm with the Johnny joint in the spanner nut...and then make the adjustment on the jeep using the spanner nut itself?
MTG added this pic a long time ago for me when I asked the same question.
Depending on how long you've had your arms on, this tool will essentially be useless. I had to resort to using a pipe wrench. If I could guess, this is the reason why EVO now uses standard jam nuts.
