Rear end is all in and put together. Although I may need an adjustable rear track bar. At ~ ride hight the axle is about 1" East (toward the passenger side). Not sure why; maybe it was always off...?
Then moved to the front. No photos but all the new control arms are attached to the frame. Also solved the big exhaust loop problem, at least temporarily. Flipped it and cut a bit off next to what is now the flange-end (downstream end). We welded that to the flange next to the y-pipe, then added a flexible section to connect it. If that ends up leaking we will get some more pipe and weld it all up.
Here you can see the clearance for the lower CA. Well you can sort of see it. Sorry for the crappy photo.
