DWiggles
I have order both front and rear setup for my JKU today. I am completely new to coilover setups and how to adjust them for ride height and preload? Want a low center of gravity and also not to be so high I can't get my Jeep in my garage after the lift and 37" tires. My garage has an open height of about 90" and little lower than most.
Been also doing some research on bump stops and plan on picking up a set of King Air bumps for the front, what do you guys run for the rear?
90" is huge, you should be able to set your jeep up WAY shorter than that with the bolt ons and 37s.
I have 4" of lift, 37s (toyos) and my jeep is just a hair over 78" tall with the factory soft top. One thing I would suggest looking into is the width, my garage door is 88" wide, LUCKY the jeep with slabs is only 84" wide... that was a close call... but height wise, your fine
