I just put on the Napa premium rotors a couple weeks ago. I was very impressed at the quality of them and the price was great. Paid. $35 ea USD.
Thanks for all of the quick replies! Since I have some of you here....would there be any suggestions on what brand rotors to replace my old rotors with? As much as I'd love to pay $100 per rotor from the stealership.....I don't. Just looking for a good OEM replacement
Ended up going with O'Reilly ones since they're local. 40 bucks a piece they'll do for now. Maybe I'll upgrade next time around. Thanks for the help guys my baby's back on the road! :thumb:
If your rotors aren't damaged and you have access to a lathe you can re-surface them or drop them at a local auto parts store and they can do it or have it done for a fraction of the cost.
Adjust to less than .005" runout or less at the mounting flange. 100 surface feet per minute / .024 inches per revolution. Re-machine both sides of the rotor during the same setup yo control parallelism to .002" or less.
Left is before / Right is after. Minimum rotor thickness is stamped or cast on the rotor. Find it & Respect it!
Just looked at your profile. Being that you're running 35s, I would definitely upgrade the brakes at some point, but if you're looking for a quick OEM replacement, I've had good luck with any parts store replacements. At the same time if they've been on the shelf for awhile, I've had several cases of warped rotors right out of the box. Those can be machined if there's an issue. Most of them are 20 bucks a piece, so you pay for what you get, but for basic safety, they're fine. Post some pics of your train horns by the way.
This can be helpful with good quality rotors and with that you probably don't need to turn them. However cheaper rotors are just gonna wear out even faster after you turn them. Since your just making the cheap thin metal even thinner. I'd advise against it and just buy quality brake parts
Yeah I tried to get them resurfaced at O'Reillys and 2 outta 4 of them were not within spec so they wouldn't do it so I just bought all 4 new ones and called it a day. Got 75k miles outta them so I'm not even mad
Sounded like the OP had the stock setup and original OEM rotors which are defiantly worth re-surfacing if they are not damaged (grooved from the linings being worn through).
I disagree with your statement "good quality rotors and with that you probably don't need to turn them". What exactly are you suggesting? That you should just replace pads without re-surfacing or replacing the rotors? I hope not!
The rotors pictured are from my 2003 KJ with 150k. Last fall I decided the replace the pads & shoes. I measured up the rotors and found that I had .035" above the low limit. I turned about .01" from each side and voila, like new rotors. In all it cost $85 for ceramic pads and standard shoes plus about four hours to turn the rotors and complete the job. Good for another 150k!
