Nope. Just a evo no limits on a rubi sway bar. The right shock/bump stop combo will do you pretty well.
Depends on how much bump u have. If anything, youll beed a bit more so your shocks dont bottom out. The longer your shocks are, the more of an issue it can beDid you have to change your bump stops when you installed the rock stars?
Ok thanks. I have the 3 inch enforcer with bilsteins. I think the bilsteins might be too long. Maybe I'll switch to the ranchos.
see how much shock shaft you have showing at full stuff in the rear
hahaha i see someone finally read it.....Did you mean to word it like this? :idontknow:
Being that you have a two door, it will work for a while but you'll need front and rear drive shafts eventually. And when you get a rear shaft you'll need adjustable uppers to set your pinion angle.
Would it make sense to just install the rear adjustable uppers when I install the lift?
so i finally got my PR44 installed and did an alignment using Eddies write-up, i was able to get the caster set to 5.1 degrees (got it checked at a shop, they could not adjust it any more than that....my toe was still off) by setting the lower control arms as short as possible, the caster is good and drivable and within spec. However, it looks like my axle is set too far back and my springs have a nasty bow in them at ride height and the axle bump stop does not line up with the upper bumpstop. is the solution here to move the axle foward with the lower arms and install a set of adjustable uppers to adjust the caster? has anyone else ran into this issue?
Went out to check a little flex since I got the 4" enforcer installed. I didn't have time to disconnect front sway bars but when I was backing down to get a better angle I heard a noise under the jeep. I know I need a new front drive shaft with this lift on a JKU. But I now will need a new rear drive shaft. View attachment 195638
Any ideas how long this will last? Ithe looks like it hit evaporated canister.
Same thing happened to me 2 weeks ago. You can get a replacement boot for about $18 or a kit (boot, CV clamps, and grease) for about $60. No need to replace the driveshaft but it will likely happen again if you wheel a lot.
Here's a video someone made on how to replace it
https://youtu.be/H38S1LCSjyU
So is a front and rear drive shaft typically needed with the Enforcer? Sounds like a common problem. Thought you only needed a front
I like the width of the 38 MTRs at 14.5. Obviously it's not everyone's flavor, but I like them. I do really like the Nittos as well but no 38.
