Ok I found this related to the rope installation on a drum that had wire rope previously. It was in the instructions for my synthetic rope install.
Note: When installing synthetic winch rope on a winch that has previously run wire rope, it is required that both the
winch drum and fairlead are closely inspected for any damage, nicks, or burrs that may damage the synthetic rope.
Using sandpaper, a scuffing pad, or equivalent, make sure drum and fairlead surfaces are free of any damage. It is
your responsibility to make sure the winch drum, fairlead and other items particular to your installation are free of
damage. We recommend a new aluminum hawse fairlead be used with your new synthetic rope.
And Overlander is correct as far as the fairlead. You need a hawse instead of the roller fairlead.
:thumb:
When I fitted Dyneema cable to my winch I had a set of nylon rollers made up for my standard fairlead, and these have been working well for the last few years.
They have been used many times since, and have past the test of time.
Yup! I know a few companies make swap out rollers for fairleads like daystar. Cheap and easy, but u can get hawse fairleads pretty cheap too.
The air compressor on a Warn Powerplant have any issues filling tires or running air tools? also can you still plumb in a compressor tank?
I have not purchased one yet but I've always wanted one.
PowerPlant HD, 12k. Haven't gotten it installed yet, but from what I have heard, it fills tires faster than the $250 ARB setup...
<img src="http://wayalife.com/attachment.php?attachmentid=15116"/>
God I want one Sooooooo bad!
Got mine essentially brand new for $1k on Craigslist. Keep your eyes peeled. I searched nation wide for mine. Luckily found one 3 hours away.
1. What kind of winch do u own?
2. Pros/Cons?
3. What kinda line do u use? Steel or Synthetic?
4. Ever had to use it?
1. Warn M8000
2. Very reliable, no problems ever, and price was extremely fair ($650 new). Line speed a little slow for what I use it for, but not bad enough that I wouldn't buy another one just like it.
3. Steel
4. Bunches of times. Everything from suzuki samurais to chevy Z71's.
great winch, super happy about getting it. got it on amazon.com.
Would like to try a superwinch on my new JK. heard their good and pretty good for the money. Although I would like to know how the VR10000 did on Vengeance. WOL...any word on that? or anyone with experience with any of the VR's?
I have the VR10000 with synthetic line on my 09 JKU and have had no problems with it, been running it for 2 years now and have used it numerous times. I would like if the line speed was a little faster but definitely not the slowest out there. In my opinion it is a great winch for the price and available parts to repair it if needed.
Who has experience with the Rugged Ridge winches? Good or bad?
2. Pros/Cons?
1. Warn 9.5ti
2.Pro- It is a Warn.
Con- Came with steel line.
3.Synthetic
-SAFETY- If it snaps it falls to the ground. Steel lines have the possibility of flying through the air. Injury or death may occur. God forbid damage to your Jeep. A fray in a steel line could leave you with a good sting on the hand even if you are wearing work gloves like you should.
-WEIGHT- I don't care for Heavy Metal.
-FLEXIBILITY- Synthetic is easy to handle and move around for when you are adding some pulleys into the equation.
4...EVER HAD TO USE IT? If you have a winch, go get stuck and learn how to use it. :rock:
....Was not impressed with the air compressor on the Power Plant. I would go with an ARB high output any day.
