as mentioned, could be a rear main seal. to check, remove the transmission bell dust cover plate - if there is oil on the drive plate you have a rear main seal leak. put the cover back on and take it to a shop, I think the transmission needs to be separated from the motor. I thought about tackling mine but chickened out when I saw how much it would take.
FYI, there is a 2 step torque process to replacing the dust cover - Torque the 4 bolts to 25 inch/lbs, then torque the 2 bolts closest to the oil pan to 40 Foot/lbs then the other 2 bolts to 40 foot/lbs - you don't want to jack up the seal in the transmission dust cover.
The oil pan looks like a 2 piece unit but Mopar considers the oil pan as the whole unit. the lower pan is sealed with some kind of heavy duty RTV and is not to be removed. Once you have the oil pan off, there are a couple of places where you need to apply RTV to seal where the timing cover and rear main seal mate up with the oil pan. There are also a couple of places on the oil pan surface to hold the gasket in place. you need to make sure to RTV these area or you'll have leaks - you should be able to tell were RTV goes since you have to remove the old.
Take your Jeep to a self-serve carwash and spray the oil pan and everywhere the oil appears with tire cleaner low spray then rinse it off (low spray) this is what I did and it cleaned the area really well. I was actually able to see where the upper gasket was oil wet so before I did anything I used my inch pound torque wrench and checked the torque on all the oil pan bolts. starting from the middle, and working in a crisscross pattern moving from back to front, torque to 105 Inch/lbs. be sure to use an inch torque wrench, the oil pan is aluminum and you could strip or snap a bolt in the motor. The lower pan torque is 85 inch/lbs ( I have my EVO skid on the pan). I got luck and found all the bolts were slightly loose and since torqueing them up no leaks :thumb:
work slow when torqueing the bolts so you can feel/hear the click on an inch pound torque wrench.
If you have to replace the oil pan seal (mopar considers the entire oil pan as one unit) you'll get an o-ring to replace the oil pick up tube o-ring, that bolt it 21 Ft/lbs.
other place it could leak from is the timing cover.
Good lluck :beer:
