Im looking into buying a set of dually's or maybe the d2xl's to mount on my front bumper and using the factory fog light switch to power them. Can this be done? Does the factory switch provide enough power for these lights?
I replaced my factory fogs with BD Squadron Pros.. pretty simple, just hardwire it in and you're good to go.. I'd just recommend looking into something to stop the flicker. The only thing I'm not too keen on is that when you do it, those dually's act like the regular fogs and will shut off when you hit the high beams. I'm sure you can bypass it, but I didn't care at the time of install.
Crap, i didn't even think of them turning off when i hit the high beams. Any ideas on how to bypass that?
This can be changed easily with a programmer such as the Flashpaq
Nice!! I already own one of those. Thanks!!
All I did with my JW's was cut the factory plug end off and splice the end connector that came with the lights. Zero flicker.
Might want to try it first before you go to the trouble of wiring in the relays
