What is the difference between those two shocks
I would get the 7000's personally. They are the 9000's without adjustability. 5000's might be a little too firm for the evo coils.
With the 7000s I'm only finding them in a 4"lift do they carry them with a smaller lift?
Ok so yeah I'm not looking for the adjustability just a lil more firm of a ride and the possibility of correcting some of the right side lean I have going on.. I know it won't be a fix without some adjustability or a spacer on the right side to make up the difference but I do think the stock shocks are a bit worn and could be some of the problem I have
I don't know. You can call rancho.
Yeah I'm on the Evo leveling kit and stock shocks with Jks quick disconnect sway bar links I'd suggest getting some new links and I'm positive you can run your stock shocks I have been with no problems and I purchased spidertrax 1.5 wheel spacers to stop my wheel rub
Ok thanks. I plan on getting the spacers as well. What size tires are u running? I was thinking about 295/70 17 trail grapplers just not sure if they would be too much
