Built one ton question.
jkodak
If you had a semi limited amount of cash to put towards axles, would you build ford dana60's or keep your Dana 44 in the rear and buy a prorock 44 for the front? And if you've built dana60's, any regrets? And go...
I just pulled the trigger on a PR44, opting to reuse all my stock components in a heavier built Dana 44 housing rather than "beef up" my factory. I'll be regearing again so I'll swap the axle myself and have them put the guts back in. A local shop tried to talk me into installing sleeves and gussets but I'd rather put that money towards a PR44.
When the day comes to do an LS conversion I'll upgrade to the 60's as well, but that's a long ways off so I'll have plenty of time to save up.
If you have the knowledge, tools, and time to build your own 60s then that will be a better option hands down.
If you have the tools to do it, go with the 1 tons. Artec makes a truss swap kit to swap in the Ford Dana 60 front and Sterling 10.5 rear.
Grubbicon, hhunter and myself are all going this route over the Dynatrac 44 front.
This way is more time consuming than just ordering from Dynatrac because they do all the heavy work for you, all you have to do is bolt it up into the Jeep. Plus I know a lot of people will say stuff like "Dynatrac comes with a warranty" which is true, but its only for like a year, which too me, doesn't make it worth the cost. Dynatrac makes a damn good axle, but if I can swap out 2 bigger axles for the same price as their 1, it just doesn't make sense to me.
That's just my .02 bud
Check out Grubbicon's build thread on here. He is currently in the process of putting a front D60 and Sterling 10.5 in the rear. Depending on what tire size you're wanting to run, going PR44 and keeping the rear 44 is probably the cheaper route.
It depends on what size tires you want to run. If your going 40's then doing a pr60 f/r would be the better way to go. If staying 37's or less than the stock rear with a pr44 front would suit you well.
Yes, the prorock route would be just a bit cheaper. But I budgeted a front and rear swap, with artec truss swap, it's a bit more money, but I fear I will get this swap done, and need additional upgrades to make the rig drive comfortable. Steering issues... Etc. any thoughts? Or am I worrying for nothing?
I agree... the sterling rear end supposedly hits the gas tank from what I've read. so will i need to order a 2 door gas tank? or try to find a 14bolt rear instead of the sterling?
I'm not 100% sure, but I'm thinking the 14 bolt will too, plus you need to shave the bottom of it since it hangs down so much. But if I were you, I would just find a 2 door gas tank from a junkyard or something.
A couple things I realized I forgot to say in the PM is that the 14b is normally a few inches skinnier and for the people that may be wanted or not. Also as far as tank goes Ive guys say some aftermarket yokes will clear. Im not really sure if mine will or not yet but I think im going to try denting mine for clearance first since my tank is already in pretty poor shape.
