Sway bar links contact with coil perch
No problem, so what do you think is causing that
Got behind my computer and gave the photo a closer look. Are you saying that it's hitting right along the side of the perch - where that little brown mark is? If so, your sway bar has shifted over to the driver side a bit. This is common after installing a lift as your track bar will pull your front axle in that direction. A drag link flip/track bar relocation bracket or adjustable track bar should help correct for this but, the shift could have happened during installation and just never moved back. The sway bar is just held in place by rubber bushings and you should be able to move it back over to the passenger side using a pry bar. If you find it difficult to move, loosen the bolts securing the bushings to the frame rails a bit and that will help out.
