PSC rocker knocker
Guascone
Hi, I have a doub...I have the PSC rocker knocker body mounted. If I have to lift the JKU from one side whit the Hi-lift jack can I use it? Or I risk to bend it?
Thanks
I have the Frame Mounted Rocker Knockers and haven't had any problems with them, I don't think there is too much of a difference between frame mounted and body mounted in regards to a highlift jack, I would assume you will be fine as they are supposed to protect you from hard impacts on rocks..
bottle jacks are also a lot nicer and user friendly, also take up way less space. just some food for thought!
:) I agree with you about the bottle jacks. It can't be used everywhere and I prefer to know what kind of possibility I have in order to avoid the risk to make trouble... :)
In Italy we said: "the good luck is blind but the misfortune sees very well"
Thanks for your feedback!
Yes you can. Ive done it a few times. This is a picture of when I did it because I had to reseat the coils.
