I'm in Rancho Cucamonga if you need help. There isn't much to it though
Under jk write ups page 2. Strizzychris did a real good step by step install with pictures.
It was a good write up but not doesn't show how to install the stinger on the bumper
Install the stinger with the 8 bolts on the front of the bumper. Then drill through the 6 pre-existing holes in the stinger all the way through the top of the bumper. Then install the bolts, washers and nuts. It's really simple but you might want to have a couple extra drill bits. 1/4 steel is hard to get through.
Any tricks to working the inside the bumper, getting the washer nuts on and tight. Seems like there isn't a lot of room to work
Not the upper outside corner of the frame horn to get the front bolt in. Otherwise it's really hard to get to.
Umm huh? :thinking:
Notch. Sorry.
Notch the upper outside corner of the frame horn.
For mine we drilled the holes for the stinger with the bumper off but installed everything with it on the jeep
What did you guys do for the wires that are hanging out. Like the fog light bulbs do you just zip tie them behind the grill?
