seanb123
Sorry for the delay here, I've been busy with other projects. Here is a simple (As simple as I can make it) diagram to run an ARB locker from the factory switches. Note: If you have done a Rubicon Locker bypass circuit this mod still works. In my case, I can allow the factory system to "think" it is in control or I can control the locker as I see fit.
This is for the rear locker only. The wiring would work for the front as well but I imagine the wire colors are different. Additionally, I have a 2013' Rubicon. I have no idea if the colors have changed over the years.
Why would one want to do this over just wiring up new buttons.... Well after a recent wheeling trip with the wife's JK sport (that has aftermarket lockers) we were plagued with ESC issues and it dawned on us that the sport stability system may not know how to properly control the axles now that they are locked. (I.E. If an axle is locked the system should not pulse the brakes in an effort to stop a slipping tire on the other axle.) It was with us and was the primary cause for several stalls. To shorten the story here, I confirmed that the ESC does monitor locker status on a Rubicon and when a locker is on it will not do this. When the lockers are off even a Rubicon will use the brakes to attempt the best traction. By wiring the circuit above the computer thinks it is still in control and has a properly locked axle and the ESC should behave as it did before.
In reality, I think the circumstances that this is an issue are few, but it still could be a factor and honestly it was a pretty easy work around. As a side bonus, the factory buttons still have a function and the dash light doesn't flash.
Hope this helps someone!
I'm trying to follow your logic here. You think the traction control will fight with you while the locker is on? The locker keeps wheels spinning at the same speed so traction control sees nothing wrong there. Would not apply brakes. Please clue me in if I am thinking about this wrong.
