Sounds to me like your just as much of an asshole as everyone else on here!
Does the wiring allow you to disconnect at the door so you can still take them off?
I thought I would try to give you more helpful advice and hopefully it will address your concerns. I can tell that you are having trouble with this and it is only fair that we do everything we can to help you.
You first want to ensure that there is a connection, so you would want to use one of these:
http://beforeitsnews.com/contributor/upload/260402/images/Tongue3 -500x500-500x500.jpg
You'll know when you have a good connection. Now, in order to disconnect the wiring at the door, you should use one of these:
https://pirategeorge.files.wordpress.com/2013/02/gasoline-chainsaw-cs2500.jpg
After that is done, then you will attach the lights. Attaching is fairly straightforward, you just apply this:
http://www.factslides.com/imgs/Metal-Nail.jpg
with one of these:
http://lghttp.18445.nexcesscdn.net/...b33525d08d6e5fb8d27136e95/v/5/v508_hammer.jpg
Now if anything gets stuck, use this:
http://www.rense.com/general79/d05.jpg
Once you are all done, all you will need is this:
http://www.tcpcode.com.au/wp-content/uploads/2014/01/Credit-Card-3.jpg
To clean up any imperfections.
Good luck!!!
Jersey, yeap your probably right. This fella has been acting like he was born in 81. Just seems most of the trouble makers that come around are posers...you know folks that continually hide behind others so they can look the big shot. I'm about more then a little tire of folks coming here and disrespecting our Host and causing a uproar. I dont think its rocket science. To understand that one is not forced to be here. So, folks like this guy should just stay out. There is so many good folks and good subject matter here, that its just a shame these nitwits, just cant stay to them selves.
