JakeJK
I think mostly bump steer usually from the drag link and trac bars no longer parallel.
Could be flighty steering also but I believe that was from your castor being off which would be fixed with front lower adjustable control arms.
The steering stabilizer is not needed on a properly set up suspension and steering. If one is preferred I would recommend a factory one. Most aftermarket ones cause a push one way, causing the vehicle to drift.
Yep I defiantly have bump steer, it's not awful but it's annoying
