Currently putting the
Wethy
Lift in have a couple questions
1. Should I loosen both sides of the track bar and then re torque both or just the axle side.
2. Should I Retorque all 4 sets of control arms at the same time or can I do the front once the weights on the tires and then the tears once I set it down or all 4 while all for wheels on the ground?
3. Is there a way to centre the front axle as much as possible without a draglink flip or adjustable trackbar I tried to find the write up but had no luck on my phone
1. Yes both sides.
2.yes just torque them all once all 4 are back on the ground. Make sure you torque your whole suspension to spec once it's on the ground.
3. No. Only way is to do a drag link flip with a raised trackbar bracket or with an adjustable trackbar. I personally would do the prior.
What size lift are you installing?
1. Yes both sides.
Ok awesome and I had planned on doing things that way.
And 2.5 coil gonna get it together torque everything on the ground then see if a draglink is necessary if it is I'll be ordering tonight ha ha and agreed the DL flip seems the better option
Honestly you will be fine without it. I ran without one on my 2.5" lift for almost two years with no problems. Only reason I got one was because I got a PR44 and planned on upgrading my suspension soon after.
Sweet 300+ saved lol more mods!
install went well. first test drive went well.
no death wobble
so i feel like this meme is appropriate
