Hello all. So I am trying to decide how to measure the size bump stop I need. In my mind, I'm thinking that I'll flex until the tire gets close to rubbing anything, measure the distance that would be filled by said bumpstops, and get that length. Am I right?
Well I have the EVO leveling kit, which I believe is 2 in the front and 1 in the back? However I plan on running high clearance fenders and 37s, don't want them to rub anything
Alright. So I'll find a 2 inch bump stop extension?
More for 37s?
Since it came up in here is there any rule of thumb as to when a coil is over compressed? Like as long as the rings aren't touching it's fine or keep a minimum of x amount of space between the rings?
3" bump stops for 37s (with flat flares) no matter the lift size.More for 37s?
That's what I would do but with the intentions of running 35s
that should be just fine until you upgrade your kit. Adding longer shock and going taller will mean needing more parts.So if I understand correctly:
I am putting 2 inch puck front. 1 inch rear. So I will need 2 inch bump stop extension front and 1 inch rear?
Also I am going to trim stock fenders flat.
